I have the power adapter but am looking for a docking station to use with the computer. I have been unable to b=get a part number from gateway as it's an older laptop. If I understand the way these things work, you dock the laptop and use an external keyboard and monitor and you can power the computer on and off with a correctly matched docking station. I just need a part number so I can find the correct one.
SOURCE: gateway mx6448
The biggest removable door held on by about 6 screws on the bottom of your laptop is what you need to remove. Once inside you will see your heatsink! Very easy to access, I wish you luck.
SOURCE: Gateway laptop 450ROG video issue when using a projector
Honestly from the information you have listed it sounds like the issue is with your projector, not your laptop. If your laptop was having display issues it would be consistent on anything it was attempting to output display to, such as your monitor.
The projector sounds like its out of focus and possibly has a bad back light in it, I would suggest contacting the manufacture for a possible resolution.
SOURCE: Plugging in Laptop results in no power.
smoke a blunt and go to sleep and try 2morrow.............*****
