SOURCE: sub-zero 650 / bottom freezer
Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
SOURCE: freezer stuck on -20 degrees
well it depends on how long the door was open for during the cleaning, your evap coil was unable to cool the unit due to the warm air coming in, that will cause the evap coil to over frez . un-plugging the unit may work but the best thing to do is force it into a defrost you can do that by pressing and holding the ice key on the key pad for 10 sec or till you hear the freezer shut down this will thaw the ice on the coil and the unit with come back on within 20 to 30 Min's
SOURCE: We have our Sub Zero model 650 frig set to 35
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
SOURCE: Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
