PC Chips M810DLU (M810DLUV75C) Motherboard Logo
Erol Kane Posted on Oct 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amd duron mobile duron 4 1.3Ghz
Couldnt find any driver update for my cpu amd mobile duron 4 1.4Ghz and the one i found isnt sufficient...?
Anonymous
Level 2:
  • Expert 341 Answers
  • Posted on Dec 01, 2008
Anonymous
Expert
Level 2:
Answers
341
Questions
0
Helped
149285
Points
907
  • Anonymous Dec 01, 2008
    The VGA driver is the one you want.Your model has the 740 northbridge chip from SIS.
1helpful
3answers
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
I got this Presario 700 from a friend. it has a
Compaq Presario 700 Memory
Maximum Memory 384MB
Memory Slots 1 (1 bank of 1)
non-removable base memory 128MB
Machine name: Compaq Presario 700
CPU options: AMD Mobile Duron (900MHz)
Chipset: VIA ProSavage KN133
HD Bus: Ultra ATA-66
Front Side Bus options:
Memory Speed options: PC133 144pin SDRAM SODIMM
Hope this helps you out. Have a Happy and safe 4th of July weekend!
2helpful
2answers
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Bios Cpu
Here is the weblink for your model  to update BIOS and Driver. Confirm Version number. You could consider upgradeing  your CPU to one of a faster speed.
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=203&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
2helpful
2answers
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
1helpful
4answers
Pcchips M810dlu v7.5c and amd duron pro2000
hi bajazzo1954,
the cpu would be fast on amd duron pro 2000
it would be better for ur pc
regards
shailesh
1helpful
2answers
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Top PC Chips Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
