The nokia 3110c restore security code can be sorted by going to:
http://www.lur.nu/nokia_mastercode/security_code.php type in you IMEI Number, to retrieve your IMEI number type *#06# this will generate a master code use this to restore your security code. - thanks Anand -
Please follow the instructions mentioned in the below weblink so that you would be able to get the Nokia 3110C phone reset.
http://en.kioskea.net/faq/421-restoring-your-nokia-phone
Thank you for your time and best wishes for your effort.
open menu > go to settings > restore factory setting > put the
password 12345 if you have not changed it <> this is for restoring
your phone.. for formating put all your files in card memory and format
it by phone or by your computer...... now everything is new i hope this
helps you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory. Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting. Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone. Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory. Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card. Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue. Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library. Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone. Cause 5 - MP3 files Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Jatin,
If you have forgotten the security code then you can not use your phone at all. Answer is tho go to the nearest Nokia Centre and get the firmware reinstalled. There is no magic key that can open any and all locks.
Normal
0
false
false
false
font-size:10.0pt;
suggested this.
