Toshiba Thrive Android Tablet Logo
Posted on Feb 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i am on skype video, the other person only sees a greenscreen, is it my tablet
I can see the other person, and myself in the little box, but they can't see me, only a green screen
Anonymous
Level 2:
Champion:
  • Expert 274 Answers
  • Posted on Feb 08, 2012
Anonymous
Expert
Level 2:
Champion:
Answers
274
Questions
0
Helped
121431
Points
332
It should be camera problem. Take it to Toshiba shop and check what's up.
Android 4.0 Tablet PC
Any solution why I can't received any calls in XPOD phablet.
How to fix Samsung Galaxy S4 that can't receive text ...
thedroidguy.com/.../how-to-fix-samsung-galaxy-s4-that-cant-receive-tex...
Aug 14, 2015 - A phone that can't get signal can't send/receive text messages and make/receive phone calls. In this step, try to see if the phone is getting a ...Missing: xpod ‎phablet
Getting started with Skype (Android tablets) - Skype Support
https://support.skype.com/.../getting-started-with-skype-android-ta...
SkypeWith Skype for Android tablet, you can make free voice calls and video calls, ... With this option enabled, you don't have to tap any buttons to answer incoming calls. ... a replacement for your telephone and can't be used for emergency calling.
how to make skype video call of xpod tablet pc - howdroid.net
howdroid.net/q/how-to-make-skype-video-call-of-xpod-tablet-pc.html
How to make Skype video calls on Android using Fring ... With either, we can make andreceive Skype calls, but we cannot see the other person. ... but yet can't figure out how to make a video call, I can't see this option anywhere, any idea?
How do I activate my microphone on my samsung galaxy tablet
reset settings,,,otherwise mic should be change by an expert,,,or use headphones
1helpful
On Skype a call comes to me on my iPad with the picture of the caller but my image does not appear on the callers screen?
Making video call iPad. This may be helpful.
Do you have a profile picture set up?
Are they able to see you at all during the call?
Which iPad do you have?
How can i video my grandson
Not sure but should have two cameras, one on front one on back. In the settings when your in camera mode there is an icon that looks like a camera with two little arrows around it, select that. Hold the screen FACING you. In the corner there should be a small box with your grandsons face in it (His machine has to be set the same way) On his machine your face will be in the small box. The rest of the screen will be taken up with your face (thats what your sending to him) The same will be on his machine. His face will take up most of his screen and thats what your seeing in the little box. Business call it video conffrenceing.
1helpful
My zeepad wont do video
There is an option in Skype settings to turn on video. Check that it is on. IS the camera in your tablet working?
I have a cnm 9.7 android tablet seems to work fine except the microphone on Skype I can here the person I am calling but they cannot here me and I can't find a setting for it .. It does however work on...
regularly it should be on working , try to call with simcard , if it works fine mic is ok and app has problem , you should uninstall then install other version
I just brought a he Sharper Image M18A" Tablet. Can anyone tell me if you can use Skype - as in see the other person. I know it's to do with the cameras on the tablet but when I brought this I wa
If you don't see the person you are chatting with on Skype, the issue is probably on their hardware. You do need to "Enable Video Call" from the Skype app's Menu after initiating a video call. If you aren't seen on the other party's side of the call, then it's your device settings that must be adjusted.
Does your tablet have a front-facing camera and Android version 2.3 or better? (The M18A is listed as having Android 4.0) If so, then you should be able to video chat with the Skype app. When you use the rear-facing camera, obviously there are issues with the other party seeing you.
If you have a front-facing camera, make sure that this is the default camera while the Skype app is closed. Open the default camera app and tap the icon to toggle the front camera interface (if needed). Then switch to video mode. Return to the home screen and open the Skype app. Login and start a video call. Then press Menu (in the app) and "Enable Video Call".
If this doesn't work, you may need the IP Webcam app. This is available at the Play Store. After setting the default camera, set the resolution and the frame capture rate, among other settings. Next, follow the directions for using Skype for a video call.
I hope this helps.
Can not male video calls on skype
is your webcam plugged in or configured? skype takes away the option for video calls if a webcam is not recognized
Skype downloaded on my galaxy tab but it does not allow me to sign in. I have uninstalled and re-installed and same thing. Skype does not seem to work. When it did work, it did not give me video...
You should be downloading the application from the Android market. It may not be the application, but the tablet that will not allow video capabilities. Try to re-install Skype then restart your tablet.
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
