Whenever i am going to open exel files, its open slowly. kindly give solution.
It could be because you have unnessessary add ins enabled. Go to Excel Options, Addins, Manage Addins and make sure theres nothing you dont want enabled.
Hi Sahil,
This can be difficult to resolve on the first pass because there is so many things to consider. I have no idea what your experience with excel or computer maintenance is. All my training in industry has told me is go for the "low hanging fruit" first (try the easiest stuff first).
1) When did you last defrag your computer. That can be a fast easy fix. I don't know what your operating system is but you may have a defrag program included as part of the system.
2) How much memory do you have installed and if you have added some did it match what you had installed because memory will run as fast as the slowest stick installed.
3) Any other programs running in the background? My antivirous program is scheduled to scann at specific times when I would normally not be trying to be productive with my favorite programs. I have all the memory installed that I can and if my antivirous program is running and I try to do something else my system tempts me to persue fishing instead of computing just so I could use my machine as a anchor.
4) Do you have an infection of malware to contend with? When has the last time been that you scanned your system for system leaches.
5) was there a specific time that the software slowed down and if so what was done to the system at that time. Can it be undone?
6) Are you the only person on the machine?
7) Just how slow is slow? My machine takes 2 sec to load excel - 5 sec to load a spread sheet that I have been collecting data on stocks for 3 years but is a rocket processing the data and developing the individual graphs that is responding to the macros commands.
So is your expectations of the program realistic?
Investigate your issue and try to reason out what could be going on. Collect more data about your system so I can better guess from wayover here.
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Evenif this is not what you wanted to hear please don't forget to rate the answer. I can always learn from your opinion of the service provided.
Thanks
Glad to be of assistance
try tupdate excel once again man...
may be some program filess will be missing...
i m 100% sure it will solve u r problem
best regards & best of luck..
