When I try to turn on tv the light goes green, there is a clicking noise from back of tv and then it instantly turns off. Checked all plugs and nothing.
check your manual, back pages trouble shooting...number of blinks ..for your solutionscheck your manual, back pages trouble shooting...number of blinks ..for your solutions
You can't post conmments that contain an email address.
Check for bad solder on
convergence module. May have bad stk's. Do not neglect looking
for bad solder on dsignal and defl boards. Mitsubishi is very prone
to bad solder.
With set unplugged remove rear cover and follow the power cord to the fuse--good or bad? This set should also have some led lights there that are green or red---look to see if any are lit or if when plugged in with back removed which come on or go off instantly, the reason I ask is those are each tied to a voltage source and will point to where the problem MAY be.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
green light flashes twice then goes back to red.
