My ds game is not working
I had the same as my toddler changed the date to 2098 (kids at least the r4 still works ) just check the date as some time is a child has hold of it they change the settings and do a silly date witch make the r4 card think that it has expired or the data on the ds has hope this helps and thanks for the help aswell =D
My nds says wrong data or firmware expires please check NDS machine data configuration
SOURCE: system date error please check nds system date
Change your ds date back before 14 april 2010. Now you can play.
Wait for a kernel update.
See the message below from the manufacturer of the R4 cards.
gr
Omer
Due to the fault of our R4 team,except R4(I) SDHC V2.0,all the kernels can not work normally base on the date after 14th, April, 2010. The issues are the system date error and when you booting up the consoles, you couldn't enter into the main manu. We are awfully sorry for this. The temporary solution is to adjust your system date before 14th, April, 2010. R4 team will remedy this bug with the latest kernel and do the activity to reward the consumers! The latest information for this activity will be released at www.r4isdhc.com and www.nds9.com. Please pay more attention to this!
SOURCE: System date error! please check NDS system date
change the the date on your console 1 day earlier
SOURCE: system data error!Please check NDS system date.DS lite will not a
I did have this problem to I have put the card out and than i did go to the calendar and put it back a year and than i turn it of and insert the card back and turn the ds on and than it has WORK so simple like that.
SOURCE: Ds lite with r41 reads system date error please
Go into system settings on the console and change the date back by 12 months
SOURCE: system date error! please check NDS System date
I had the same problem. I fixed it correcting system date *before* the real date ( 1 day before in my case). It worked!!
