Question about Maytag SAV5701A Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
I have a 2.5 yr old Maytag SAV5701AWW wash machine that recently started to make a loud howling noise during the spin cycle. The belt burned off recently (on the motor pulley was where the burning occurred) during a spin cycle. I replaced the belt and also spun the drum and agitator to see if something was 'locked up'. Both seemed to move freely. After changing the belt, the machine still makes a loud howling noise on spin cycle (can not hear a person talk 5 feet from you!!!). Some other observations: the drum seems to stop abruptly when the spin cycle stops, the drum/motor/pump assembly move back and forth a great deal when the spin cycle begins.... Any thoughts? Thanks!!!
  • 12 more comments
  • Anonymous Mar 04, 2008
    yep, I have the same problem with mine. I'll calling. thanks for the info!
  • Anonymous Mar 14, 2014
    This might not be the right ID #. Mine is from 1998.
  • Anonymous Mar 15, 2014
    agitator doesn't move and wash basin doesn't spin. Motor does make noise, but belt doesn't move. Belt can not move freely
  • Anonymous Mar 19, 2014
    machine makes a horrible noise while agitatiing and spinning, wife cant take it anymore, just had a part replaced that allows it to change cycles, $233 amazing, $156 in labor for 2 screws!~!
  • Anonymous Mar 21, 2014
    my washing machine will not do a spin cycle. the drum will move freely when not turned on.
  • Anonymous Mar 22, 2014
    Washing machine shut off during the rinse cycle, the augutator was locked up,I changed the setting and it spinned freely. I tried the next day to turn on machine water started to flow then stopped. I can hear the motor but nothing happening a y ideas?
  • Anonymous Mar 24, 2014
    The drum of my warhing machine seems to be loose it makes alot of noise when it goes into full spin and the belt keeps coming off
  • Anonymous Mar 26, 2014
    There was a noise inside the drum at certain times in the spin cycle that proceeded the latest problem
    I recently replaced the belt and the belt is not the problem. The smoke has a burning rubber smell to it. Trying to determine if this would be a bearing or the drum seal. There is no excess noise when spinning, so speculating this is the drum seal. Is this most likely?
    machine will only agitate during spin cycle?
  • Anonymous Mar 27, 2014
    agitator moves but drum won't spin
  • Anonymous Mar 29, 2014
    Does not agitate nor spin and makes loud noise. Black rubber belt at bottom is worn out nad come off the motor or fan
  • Anonymous Mar 31, 2014
    wash machine just recently begun to get loud during the spin cycle.
    President:
  • 878 Answers
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
6ya staff
SOURCE:
Mvwc300vw0
The howling (squealing) noise is likely the belt, if I had to make an educated guess. Of all the fixes you could be stuck with, that's one of the easier ones.
The reason I suggest that is because even though it probably isn't washing to its fullest potential either, you wouldn't really notice it, if it's still able to do a little agitation. Once the spin cycle kicks on, the motor applies a lot of power, and if the belt is loose, it'll spin that belt around the wheel, creating a really soothing and serene squealing noise, causing average humans to start seeking sharp objects with which to slice their wrists.
Sep 02, 2012 | Maytag Washing Machines
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Dec 14, 2009 | Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Burning Smell when spinning
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Jun 09, 2008 | Maytag Dependable Care LAT9416
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Whining during spin cycle
zato2
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
handiman518
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag SAV5701A Top Load Washer Logo
1,886 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
