SOURCE: burning eyes, can't breathe.
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
SOURCE: Need Manual for Reddy Heater Model M30
Click on this link to see if this is your heater http://12.153.20.74/manuals/113893-01D.PDF . If this is not click on this link and put in your info. I hope this helps you. http://www.desatech.com/manuals.cgi?products=Construction%20Heaters Don't forget to rate my answer.
SOURCE: reddy heater,kerosene.no manual
The manuafactures website is still up. If you have the model # (should be located on the rating plate on the unit) you should be able to pull up a copy as long it isn't too old. Go to www.desatech.com
I hope this helps...
LSG....
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
heater...
Reddy
Torpedo
heatman101
heater...
Reddy
Torpedo
heatman101
google it I just downloaded the manual for my 35000 btu
