Oh No, another shop job. It sounds like the inverter or tube for the LCD are on their way out. I'd recommend a watch on Ebay for the same model but with maybe a bad lens and swap the LCD and the board it connects to. A very simple job if you take you time and remember where the screws go back and which length screws go where. Because the camera is 4 years old and still has some life in it you may be better off using it as it is and utilize the optical viewfinder instead. Just remember, you only see about 80% of the actual photo in the optical VF so allow for that when taking shots. You can always use Photoshop etc to crop out what you didn't want. Just use the LCD for changing menu setups. BMW
Hello, your problem is related to electronics, and it will not be fixed without opening the camera. thereafter i suggest to reset the camera, if problem still remain, go to fuji shop...... good luck...
