Need to run laptop through tv screen but cannot switch laptop display
SOURCE: hp pavilion zd 8000 dvd not working
you need drivers. to play DVD's I found a killer totally free player that does nothing but play movies. no sypware, spam or reminders to buy or limitations. http://www.videolan.org/ speaker are going to be audio drivers. right click my computer - properties - hardware - device manager, what ever needs drivers will have a yellow question mark
SOURCE: HP Pavillion ZD8000 display problem
you have to replace the display panel, for this you can order the panel from the HP itself, it will be much cheaper, and for replacing consult a technician, it won't cost more,
or you can attach a external monitor through the vga port and can do your work.
SOURCE: HP Pavilion dv6308ca hotkey functions (screen capture)
It should be FN+Insert on DV6000 to take a SC
SOURCE: I have a HP pavilion zd 8000 and I need to replace
try this http://h10032.www1.hp.com/ctg/Manual/c01383095.pdf
Removal and Replacement Procedures
SOURCE: I have a zd 8000
check out this link. its a little on the pricey side but i guess it just depends on what your budget is. http://www.upgrademaster.com/pavilion-zd8000-c654/60gb-internal-notebook-hard-drive-p26085.html
Testimonial: "Very quick response !!!!"
Are you holding down on the Fn key, and AT THE SAME TIME, tapping once on the F4 key? Post back in a Comment.
Yes tried that, and pressing the windows button and P but nothing happens. I get options on other computers when these buttons are pressed
What Operating System? It is either the settings in Windows, or a bad Keyboard.
Press the Fn key down, and at the same time tap on the F4 key. (DisplayToggle-Over key)
