Moved set from digital cable box. Now the ez scan will not locate hd channels.
Hello
you want to reset all parameters of your TV to Factory default, I assuems and posts this solution.
1. Press the "Adjust" button on the remote handset; press "Up" or "Down" button to select the "Reset" option.
2. Press "Enter " button and Use " >" or "<" button to select "Yes".
3. Press "Enter" button.
All parameters will be set to its original Factory Defaults.
SOURCE: DIGITAL/HD CHANNELS
hi there, i have the LG 50in Plasma and just updated the channel connection by doing the following:
1. Make sure your remote is in "TV" mode.
1. Press the Menu button.
2. Highlight "Auto-program" (Should be the first item on the Menu)
3. Scroll over to "To Start" and press OK.
The TV will automatically search for all available analogue, digital and HD signals and may take a few minutes.
Once complete, it will return to the last program you were on and you will find all channels available.
To check the guide or the time, you need to press the "guide" button. Make sure your remote is in "TV" mode. Alternatively, pressing OK at any time shows you the time and channel that you are on.
Hope that helps!
jp
SOURCE: No sound on 90 HD Digital Channel
You need to get in touch with Lg and they will help you. All you need is for them to either post you a usb with software or they can email it to you and you can put it on a usb and put it on your tv via usb port and update the software on your tv.
The frequency for the new channel is not on your tv but they will give you the software to update so it works.
SOURCE: Channel Memory
Don't use EZ scan,reset it to Factory Setting.Use Ch.set up go through the whhole process every channels should be there.
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
