Hello
Check all the input connections to the sub for any loose contact.
I just did that and it still does it
Hello
If there is no loose contact to connections, the fault, crakcing noise must be due to some disc ceramic capacitors on the filtering board of the amp. This boad can be located inside the woofer cabin. Check it. Take it oug and check. You must have to open the woofer to access this board. All sockets out to other speakers will emerge from this board. Check whether there is any loose solderings to these sockets.
I did that already. I took all the wires off and reconnected them
I tried to get the back off and could cot figure out how to get the insides out. All the screw were removed but I did 't want t force it. It seemed loose but still something was holding it in. If I missed something I would appreciate it if you let know what I missed thanks
