When using my washer on the Perminant Press cycle, it stops working after the drum fills with water, then the timer makes an unusually loud noise. To get it to continue working I am able to utilize the Normal wash setting.
Since this has started I've washed everything on Normal, but I am confused as to what could be causing an issue for only one cycle type.
Any suggestions/ideas?
Your timer is causing the problem more than likely, valves , pump motor is working so your timer itself is not change it most of the jobs can be done by the homeowner they are a quick connect disconnect and maybe a screw or a catch holding it just look at it how it attached to the console and reattach it the same way
SOURCE: LTE6234 Whirlpool Twin Thin Timer Broken?
The problem I have with my Whirlpool ThinTwin is that when I pull the washer knob the water does not start filling even though there is water in the apartment unit. The dryer works so i know there is power and not a circuit breaker issue as I have checked that as well.
When I turn the knob and pull in any position nothing happens. Any suggestion would be greatly appreciated.
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
SOURCE: whirlpool washer ultimate care II lsq8500JQ1 top...Problem
Ok folks to change the lid switch on these and many top loading Whirlpool, Maytag, Kenmore, etc is quite easy.
Steps to replace the lid switch:
1. Remove unit from AC.
2. Remove the loading door from the unit, or using some duct tape tape it closed.
3. Using a small flat bladed screwdriver find the 2 release catches on the front of the unit between the top cover and front panel. These are just snap claps to hold the top cover down. To release the top you will need to compress the latch using the screwdriver. Start with one side, then the other. Once you have released both clips the lid will lift up just like the hood of your car.
4. You will now be able to remove the lid switch from the unit.
5. Install the new switch and close the hood of the unit.
6. Test the repair by running the unit though a complete cycle.
A great place to order the replacement part for the unit is:
www.appliancepartspros.com
They ship same day on orders placed before 3pm EST. Overnight shipping is available, however I usually opt for the 2-3 day ground shipping and save the money.
If this switch replacement does not take care of the problem, you might need to replace the control board located under the front panel. This replacement is also very easy and takes about 10 min from start to finish.
Hope this helps everyone. Cheers,
Keith
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
SOURCE: Whirlpool washing machine makes grinding noise
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
