When I try to print or scan, I receive this : a component is missing
Try to uninstall your existing printer driver. Then, reboot your computer after the uninstall process.
Once your computer comes back on, visit the Lexmark website to download the Lexmark X5470 printer driver for Mac 10.6 at http://bit.ly/yRg5X8.
SOURCE: lexmark x5470 will not print
Hi
Please check cartridge is properly fix and its not blank, check your USB cable, and uninstalled your printer driver and reinstall..
SOURCE: My printer says "missing component
Please carefully follow steps below to fix this problem:
If this doesn't help, please contact Lexmark Technical Support Center for additional assistance.
SOURCE: I have a Lexmark X4690
A quick
fix for most communication errors can be achieved by resetting the printer
and/or rebooting the PC. Frequently, issues are caused simply by a break in the
signal sent from PC to printer or vice versa. Unplugging and re-plugging the
printer allows the small amount of on-board memory on the printer to be
cleared, with the result that the PC recognizes the machine properly. Programs
continuing to run in the background of the operating system (OS) can cause the
signal to be lost. Rebooting the PC ends all programs that may be running and
makes a 'clean' start, allowing the signal to be detected.
Please visit the Lexmark website to download and install the
Lexmark X5470 Printer Driver on your computer. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
Then try to print a document to verify that the problem is fixed.
Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a page forcing ink through to clean the print
cartridge nozzles.
If that doesn't help, please visit the Lexmark website to update your Lexmark X5470 printer driver. Select your operating sytem > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation. Then try to print again to verify that the problem is fixed.
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
that doesn't help, try the steps below:
1.
Disconnect the printer from your computer.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
Delete the Lexmark print object.
4.
Reboot your pc.
5.
When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
