My beko washing machine is like paused or locked the washing timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Try unplugging the machine for 5 minutes, if that doesn't reset it you likely have a defective main control circuit board.
Just tried the reset method on beko wm140w thanks for the info works a treat
The BEST solution is:AVOID IT LIKE A PLAGUE.This i biggest rubbish there is on this planet.
Michael
What is a pcb
SOURCE: How do you reset a
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start
up.let it complete its routine (takes 2 mins or so).now the machine has
reset.select program as normal and retry
Hope this helps
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
SOURCE: unlock control lock in washing machine, whirlpool, duet
my whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
SOURCE: I can't unlock the door
fencer, you probably have a bad door lock switch. There was a technical bullitin out by Maytag regarding this (TS740). The deal is that the plunger of the switch is depressed but the contacts don't close. The machine control board senses the door is not locked and won't send the signal to unlock it. You can try to put the machine in the service mode by pressing delicates and heavy soils together for 3 seconds. Advance to the board output tests by then pressing rinse. After that press the max extract key to lock the door and the xtra rinse key to unlock the door. See if it works for you. You may want to call Maytag and inquire about the service bullitin, maybe you can get it covered. There is a manual door release in the dispenser section. The pull tab should be toward the front. You may have to remove the screws and remove the dispensor to get at it. Catriver...post back.
SOURCE: beko wm6152w turn machine on
try holding the start/pause button in for five seconds, hopefully it will restart
