Quinny Dreami - Black Bassinet Logo
Posted on Feb 08, 2012
Dreami carrycot wobbly on chasis
Hi all I add my adaptors to my chassis to add mmy dreami carrycot hohowever there seams tto be a lot of movement in the carrycot is this rightor should it sit firmly please advice me if im doing somthing wrong or how to fix thanks steph x
2 Related Answers
Anonymous
  • 42 Answers
  • Posted on Jul 08, 2010
SOURCE: i cant get the hood down on the Quinny Dreami Buzz Carrycot
There are two buttons one either side of the hood. These need to be rocked backwards at the same time as pushing the hood down. Fiddly and works better if there are two of you, but if you stand behind the pram (as if you're looking into it) and using your index finger rock the buttons back and down whilst using your thumbs to push the hood down. Good Luck, it works for me.
Anonymous
  • 286 Answers
  • Posted on Oct 18, 2010
SOURCE: I have a quinny speedi
hi
yes i believe they will quinny haven't changed anything that connects the dreami or maxi cosi all quinny have the same connections.
Quinnybuzz carrycot adapters stuck
Hi Gillian
When the Dreami is removed from the chassis, if the adaptors come off with it then this will make it difficult to remove them from the Dreami. When removing the adaptors should remain in the chassis. It might be helpful to have someone help you if they seem to be a bit sticky. The Dreami can then be removed from the chassis leaving the adaptors in the chassis - the adaptors can then be removed from the chassis separately. Clean with a bit of furniture polish and a soft cloth to aid future use.
1helpful
Can dreami carry cot fit mura 3?
The combination has not been tested or been given the required safety certificates so we must advise that you do NOT use a Quinny Dreami on a Maxi Cosi Mura 3 chassis.
The Maxi Cosi Mura carrycot or 2013 Maxi Cosi Folding Carrycot ONLY should be used on the Mura for guaranteed safe combination.
The use of a Dreami on the Mura chassis has not been approved and we cannot accept liability for any malfunction of the product combination.
Does the quinny dreami fit onto the maxi-cosi loola pushchair? If so is the same adaptors that would be used for the maxi-cosi car seat?
Hi
No the Quinny Dreami is not compatible with any Maxi Cosi chassis.
The Quinny Dreami can only be used safely with Quinny Buzz or Quinny Speedi chassis.
For the Maxi Cosi Loola chassis you should use the Maxi Cosi carrycot only.
Will a new Dreami fit on a XL stroller with the adapters that came with it?
Hi
If you have the original adaptors that came with your Freestyle then a current Quinny Dreami can be fitted to the chassis.
What carry cot fits quinny free style xl
Hi
The Quinny Buzz carrycot is called the Quinny Dreami. This is the only carrycot suitable for use on the Quinny Freestyle chassis.
How do u conect bassinet to frame of quinny buzz
You need to get hold of a pair of adaptors - they are sold on Ebay. They slot into the Buzz frame and then the carrycot locks onto the adaptors. The adaptors work for the carrycot and the car seat.
Search for quinny buzz adaptors and you will see what I mean!
2helpful
2answers
Can you put a dreami carrycot on a quinny zapp?
hi i am sorry but you can not put the dreami on the zapp due to the stability issues that it would cause
also the adapters only fit the carseat they are not long enough for the dreami to attach properly
Dreami - Black Bassinet: I've just bought a Quinny Freestyle and would like...
Yes you can. You need a set of adaptors( the same ones as for attaching a maxi cosi car seat) You remove the seat unit by unbuckling all straps and taking it off. Then you then need to remove the 2covers above the quinny logo on the sides of the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. They are marked left and right. The carrycot is then placed onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood. HTH
Quinny Carrycot Compatible with Quinny Dreami?
The Dreami for the Freestyle 3XL is compatible with the Buzz. You will need to get a set of Buzz adapters (these are the same adapters that you would use to attach the Cabrio Fix carseat) these should cost around £18 or see if you can get them on eBay!
Hope this helps.
I can not get my carrycot atrtached to the buzz frame, do i need extra clips or fittings
You need the carrycot adaptors which slot into either side of the bottom of the carrycot, then these adaptors will click into the frame in the same place the seat normally would. Hope that helps!
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
