SOURCE: vertical lines in my sylvania lcd tv
They go away after 10 minutes of what? **** She Wrote? Dancing with the Stars? Or simply being powered On? You have some cold solder joints on one of the PCB boards. Once they heat up they work perfectly. The only way to fix this is to have them reflowed by a tech with a soldering tool or have the board replaced. Good luck! Cheers
SOURCE: My puppies are teething and they bit the remote
Need to know prefix letters to model # on back of TV. Original may be available here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEARCH&mres=1&mrpn=PNFLC195SLX
SOURCE: Sylvania LC195SL9 19 in. LCD need a dis remote
hi! i have a couple of codes for your tv, just try them,
1145, 3095, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1150, 2092, 1464, 2408, 1465, 2260, 1046, 1465,
1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483, hope this helps!!! goodluck!!!
SOURCE: Problem for Sylvania LC195SLX LCD TV Channels will
It looks like your TV doesn't have a digital tuner in it. Without that you won't be able to receive any broadcast television stations. The spec sheet is here: LC195SLX the tuner is listed as just ATSC/NTSC - not digital. You will need a cable or satellite box to receive stations.
SOURCE: My sylvania LC195SLX 19" TV
Hi
You will have to open the back of the television to repair the television, and care must be taken by unplugging the power plug of the television.
A common problem for these is bad capacitors in the power supply, Remove the back from your Television and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this help in solving the problem and do take care because it contain high voltages
