Cameras Logo
Posted on Oct 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where on my computer do I plug my camera into in order to upload my pictures?
  • Anonymous May 11, 2010
    hi there
    make and model number of the camera please
    beergut707
ashburton
Level 3:
  • Master 417 Answers
  • Posted on Oct 23, 2008
ashburton
Master
Level 3:
Answers
417
Questions
0
Helped
179414
Points
1232
  • Normally you would connect the camera to the pc using a USB lead. To do this your camera should have a mini USB slot somewhere and you would plug the mini USB cable plug in to this, then plug the larger USB end of the cable into one of the USB ports on your PC (USB ports are usually oblong and situated on the back of the PC) , You may need to install some software supplied with the camers to do so.
Please remember to rate this solution.
Upload pictures
The best way to upload pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Upload pictures
You don't need a CD to upload pictures to a computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
5helpful
My Camera Won't Upload Pictures To My Computer.
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
1helpful
My pictures won't upload
You need to install the software for your camera and allow it to start when windows starts. That way, your pictures from your camera will be uploaded as soon as you connect it to your computer. Or try also to start the camera software and plug the camera to automatically upload images. To automate it, you need the software to run when windows starts. Simply add the software at system startup.
5helpful
I cant upload pictures from my polaroid t730 camera to computer
I can'tg upload pictures. I have a polarioid t11031 digital camera, and I have a USB cord ffor it, but my computer does not recognize it when I plug it in. I want to know how I can get the pitctures off my camera and onto my computer.
Upload pictures to computer
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Problem Uploading pictures
3helpful
Uploading pictures from my digital camera onto my computer
everytime i plug my camera in the usb it dosnt want to upload pics?
Uploading pictures to my computer
Hi , in uploading picture let camera on ,plug usb , detection come in screen message , et camera button ignore it / click set camera ,select upload to camera, selection of pictures then okey.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
