I have an Intel Dual Core 3.06 GHz processor and an Intel D102GGC2 motherboard with 2 GB of RAM. I need to install a MAC OS on it. Please suggest which MAC OS can I install on it. Also suggest whether MAC OS X Snow Leopard will work on it or not. Quite Urgent. Thanks.
SOURCE: UNIX suitable for biginers
I would like to humbly state, if you are completely new to Unix it may be in your advantage to start with a flavor of Linux.
Poseidon Linux is specifically geared towards the scientific community, and contains many applications and tools centered around those needs.
Here's a download link for Poseidon in English:
http://poseidon.linuxfreedom.com/
Scientific Linux, which is geared towards your ambitions is based of the Red Hat Distribution, which allows for easy installation via "Red Hat Package Management" or RPM.
Here's a link to Scientific Linux:
https://www.scientificlinux.org/
Should you feel that a true Unix experience is required, the choice of Unix would be up to you. The reason why you would have to choose a Distribution on your own is because mostly all Flavors of Unix do not come with mission-specific applications installed.
You can get Unix in both Open (Free) or Licensed.
Try this link for different flavors:
http://www.crucialp.com/resources/tutorials/dedicated-server/unix-flavors-flavours-distributions.php
Hope this information has been helpful.
SOURCE: i saw yellow questation mark
try control panel,administrive tools,computer management,device manager should see a yellow ? right click re-install drivers
good luck
SOURCE: i want to install the
1)FIRST YOU DOWNLOAD DRIVER ROBOT FROM http://driverrobot.com/ YOU CAN DOWNLOAD ANY DRIVER VERY EASY
THANKS
SOURCE: what is the main difference
1. Dual core is the generic name given to processors that have 2 cores on the same chip
2. Core 2 Duo is the second line of dual core processors from Intel
3. Other dual core processors aside from Core 2 Duo are the Core Duo from Intel and the X2 series from AMD
4. All Core 2 Duo processors are dual core but not all dual core processors are Core 2 Duo
For more info visit the link below
http://www.differencebetween.net/object/difference-between-dual-core-and-core-2-duo/
SOURCE: I used to be able
Hi, According to you if this problem arises only for this site then may be the site is corrupted or the or may be the server problem. So you must wait for the link up or visit the website for complain. If your internet connection is slow then it may happens. Because images can't be downloaded properly for slow connection. In this case contact your internet provider. You can try by changing your surfing explorer. If the problem arise in another case also then It may happens for your PC virus problem or for OS corruption. You can try by formatting & reinstall OS of your system, and must use a licensed Antivirus. Because display or graphics may be corrupted. Use updated and different explorer also in that case.
I can do that just need confirmation that will it work or not........i will download the cracked version from internet
