Question about Kenneth Cole Watches
How to get moisture out of a watch
Still works, but has moisture on inside of glass. I put a lighter to it and it goes away for awhile, but comes back. Can I put it in a toaster oven for a few minutes to dry it out?
    New Friend:
  • 3 Answers
Was about to suggest the same, to to Asda or other supermarket and get the cheapest bag of rice like £1 maybe and leave it overnight also make sure u do it in a sealed container and that should try draw moisture better.
Posted on Feb 18, 2019
    New Friend:
Ive heard people say many times to put cell phones in a bowl of dry white rice to remove moisture from them,so Im sure it would work for a watch as well. Just make sure to leave the watch in the rice over night,and make sure to have none of the watch showing in the rice---it will need to pull moisture from within the tiny parts.
Posted on Feb 09, 2012
6ya staff
SOURCE:
Watch has film inside the glass. Also, the finish has began to decay in appearance.
The film is from moisture getting into your watch. Moisture can get in one of 3 ways generally. The crystal if cracked, the crown, or the back. In your case since you have buttons for the mulch-functions of the watch you add a possible place for moisture to enter. Take the watch to a watchmaker or watch repair person. Your watch has to be taken out of the case and the case needs to be cleaned. Next the watch tec. may be able to see just where the seals failed and replace them. We of course do this. Also if the gasket is old or out of shape this is a culprit as well.
Hope this helps, gabe
Aug 28, 2013 | Field and Stream F25SLUMI Wrist Watch
My crystal cracked a couple of months ago and i got it replaced. tonight i noticed that my watch has moisture inside the crystal. what should i do immediately to ensure the watch continues to work. ...
the crystal is not properly attached it may have tiny opening where moisture goes inside. you have to bring it to watch service center immediately to avoid much bigger problem. i hope i had been helped you.
Sep 05, 2011 | Ebel Watches
Where can I get hold of a replacement glass for my sons watch which he has smashed during freshers week! Watch itself is not scrated and working OK but glass broken
you will need to get it professionally installed since you need to install it properly and have it sealed to prevent water or moisture from entering inside watch . I would say to have it done professionally around 35 dollars. I am pretty sure that the glass is at least mineral .
if you want to try it yourself you can buy online from esslinger or other similar watch parts stores.
Oct 23, 2010 | Diesel DZ1090 Watch
How to remove water from inside the wrist watch
Try putting the watch in a warm place for a day or two, to let it dry out. (one maker said that some moisture is not a problem but I guess that is depends on how much "some" is).
If the problem persists, take it to a watch repairer.
Jul 16, 2010 | Watches
Hi i wore my rolex in a hot tub & now it has condensation under the glass how can this be removed
Before anything else, put the watch is a warm place and leave it there fore a day or so, it may dry out on its own.
(Some manufacturers accept that small amounts of moisture inside are to be expected, so it may not be a disaster.)
If it proves to be a persistent problem, then its back to the service center!
Mar 01, 2010 | Watches
Condensation in dive watch
place the watch in a bag of minute rice for a day or so and check to see when its becomes clear. this tip,i will guarantee it to work in no more than a few days. be sure to loosen the stem and even the back acess to the battery to insure the moisture can escape from the watch
Jul 09, 2009 | Watches
Colibri lighter
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Dec 20, 2008 | Watches
Glass foggy or has film on inside
The film is moisture, you may have to remove the back and let if evaporate. You need new seals as it is your sweat that is causing it.
Feb 08, 2018 | Fossil ES9596 Wrist Watch
Watches Logo
235 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
