Headset Motorola BT H300 have too sensitive microphone, or better, auto-amplification is too rapid. So, in every talking pause amplification became too high and when I speak it colapse because off strong signal. It makes for listener my voice unrecognizable. Could it be fixed? BTW, my phone is Nokia 3110 but same behavior I noticed and on other phones. Thanks
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H300 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
The button on the face of the headset (same one that turns it on/off. Make sure it is off. Now turn it on by holding the button down untill the light blinks rapidly then stays on steady.
