The tax rate where I live is .0675 and I can't seem to set it up in my calculator. Any suggestions?
To change the tax rate on the Canon MP11DX (and most others):
Slide the "GT" button to "RATE", enter your tax rate and hit the "TAX+" button. Once changed, slide the "GT" button back to the "ON" position.
On my Canon LS-120PC, to adjust the tax rate, you need to press the Tax+ key, then enter the tax value (6.75 in your case), then the Tax+ key again. This will probably work with your MP11DX.
Have just used the formula to change my calculation before I do my VAT return and it works!! Thanks :0)
Thank You so Much! I was able to get the tax set with no problem using your solution : ) Thanks Again....
I need to set different tax rates for the TAX+ key and the TAX- key. Is this possible?
THIS DOESN'T WORK ON MY LS120PC
setting the tax rate on canon mp11dx
I replaced the ink roll, now it prints red instead of black. I wonder if I have the rolls in correctly or is it a setting on the calculator
How do you set the time from am to pm?
