Question about Sony STR-DG800 Receiver
Sony STR-K685 Amp/Receiver - Sony STR-DG800 Receiver
Anonymous
SOURCE:
Anonymous
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
Anonymous
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Sony STR-D665 receiver display flashes "PROTECT"
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 07, 2010
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
Posted on Jun 13, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: my sony STR-DE345 amp says "protect" and there is
The manual says it thinks there is a short circuit on the amplifier output side. If it still says Protect after disconnncting all the speakers wires there is an internal problem. Take it to a hands-on tech.
If the problem disappears, you had a short. Attach speakers one at a time to isolate the cause.
http://www.retrevo.com/support/Sony-STR-DE345-Receivers-manual/id/387bh943/t/2/
Posted on Dec 25, 2010
How do I set up receiver
HI YES YOURE GOING TO NEED A FEW RCA CABLES u. can use video 1 to plug youre tv in and use video 2 to plug in youre vcr ::::::::::connect youre speakers up to the red and black speaker terminals marked L & R..good luck
Jul 26, 2015 | Sony STR-DB1070 Receiver
Connecting a turntable to Sony STR K502P
Use RCA Cables from the TT to the Aux in on the Receiver. You may need to use a pre-amp inline from TT to Receiver.
http://www.bhphotovideo.com/ has a few.
Mar 17, 2014 | Sony STR-DE485 Receiver
Problem with SONY STR-DA555ES home stereo receiver popping & going into protector mode
You may have the speakers incorrectly connected or the speakers you are using have an impedence that is too low for the amp to support.
Sep 15, 2013 | Sony STR-DE875 Receiver
Sony receiver keeps blowing 5 amp fuses
You have shorted output transistors in the amp that need to be replaced.
Feb 14, 2013 | Sony STR-DE425 Receiver
Can I connect a passive subwoofer Sony SS-W581T to a SONY receiver STR-DH510 ? Thank you
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Apr 17, 2011 | Sony STR-DH510 5.1 Channels Receiver
My sony receiver model:str-se445 stop working giving an error "protected"
hello, your problem is the out put transistors, but before you replaced them check for any loose connections or cold solder in the pre-amp or drivers integrated circuit. good luck.
Feb 14, 2011 | Sony STR-DE445 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
Working the Sony STR-DE475 5.1 Channels Receiver
It has a dedicated sub out. you need a phono connection on one end for the amp and the other end must have a compatable connection to your sub.
You will need a phono connection to the amp from your TV. You can utilise a scart lead that has phono outputs however a TV with audio outs (the red and white leads) is the default option.
Mar 31, 2009 | Sony STR-DE475 Receiver
Sony STR-DG810 w/ Bose Acoustimass 10
Try this:
Go into the menu settings by pressing "Receiver" --> "6-Video" --> "HDMI Audio" select "Amp," not "Amp+TV"
Yeah, it makes total sense to have a very important audio setting in the video menu.
Feb 11, 2008 | Sony STR-DG810
Sony STR-DG800 Receiver Logo
173 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
