Was not working, checked brushes, they are good, pulled white wire from power & red wire to coil loose, clamped them together, hit the switch, machine functions in all speeds, odd..... plugged everything back together, now it runs fine until..... one side of the governor assy. comes loose, enough that it rubbed away part of the circuit board, is it a defect in the governor causing it to come loose or is it just running too fast? I did notice that bypassed, the machine will still function at all speeds without the circuit board even connected, what is the main purpose of the board?
SOURCE: KitchenAid K5SS mixer speeds up beyond set speed.
I have the same mixer and I believe your problem is the governor that is on the back of the motor. You can figure it out by downloading the repair manual here:http://store.mendingshed.com/kitaidparts.html The manual has all the info you need; including a troubleshooting section. The governor is availible from the the same site here:http://store.mendingshed.com/kagovernor.html What tipped me off on my K5SS was looking at the governor as it ran and I could see it moving back and forth; not steady like it should. Good luck!
SOURCE: KSM103 won't run
I had removed carbon brushes and when tried to start nothing happened kept removing brushes it eventually started
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. [email protected]. Let me know if it works.
SOURCE: My k5ss mixer will not turn on, I checked power
looking from the rear of the mixer, insert the LEFT brush so that the champfer is facing down. Then insert the RIGHT brush so that the chamfer is facing up. that fixed the problem for me.
SOURCE: I took off the back cap of a 300 mixer. then
Hi, KIMAMABELL, While working on your mixer be sure to have
the Parts List manual on hand. If you're
lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer
Care>Locate Manuals & Guides> Enter the 6 character model number,
in your case, KSM90P, and select one of the files listed under Parts List (check to see it this
matches your mixer model).
Turn to pages 6 & 7, titled “Motor And Control
Parts”, which provides an exploded view for the disassembly and reassembly of
your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder that
includes #18, 20, 21, 22, 23, and 31 which is the brush holder and brush &
Spring assembly respectively.
The brushes need to be installed so that they
both seat correctly on the armature's commutator and it’s possible when you reinstalled them, one or both brushes were turned incorrectly.
The illustration below shows the correct orientation
of the brushes and should allow you to reinstall them with confidence.
Here
are some links to several excellent websites that detail the disassembling/reassembly
of a KA Mixer for your future referennce.
Between
these three websites and their excellent pictures and descriptions and your
Parts List manual, you should now be able to completely disassemble and
reassemble your mixer.
I hope this helps. Howard, Burke,
VA
If this solution has been helpful to you, please
rate it, thanks! - hslincoln
Funny, I had asked this question around 2013 and had long since modified the governor so it wouldn't come loose any more and replaced the circuit board, surprised to see the question come up with the April 20, 2017 date.
