GE Profile Spectra JGBP79 Gas Kitchen Range Logo
Posted on Oct 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE profile gas stove igniter don't stop igniting
Please help me stop my gas stove electronic igniter, it keeps clicking even if the stove is not in use, I turned off the main switch for the kitchen and it stopped but when I turned it back on, it is still continously clicking.
  • 1 more comment
  • jbjimbra Nov 21, 2008
    All 4 of mine keep clicking at the same time. unplug ac, stops clicking. our model is jgp336wev4ww but i don't think that makes any difference. my guess is a bad spark module.
  • kiran23k Dec 14, 2008
    I have the same problem
  • joemtech May 13, 2009
    I have the same problem with my GE Profile cook top, all four ignitors keep igniting. I have tried cleaning the "gaps", however, igniting continues, is there a spark ignitor module?
Anonymous
Level 3:
Genius:
  • Master 1,605 Answers
  • Posted on Oct 23, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1605
Questions
Helped
746499
Points
3939
Take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3020
Points
The gas ignitor wont stop cliciking
The electric igniters , all 5, are still firing after the flame is lit. Turning the power off is the only way to stop it. Any suggestions?
Hi jsjone1945,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
GE PRIFILE STOVE TOP KEEPS CLICKING AND THE INGITE KEEP GOING OFF ON ALL 4 BURNERS...HOW DO I STOP IT FROM DOING THIS.
Hi pauliepaul22,
Kind Regards
JEDEMEYER1
Igniter clicking
I have a stove that doesn't light (click) I've replaced the igniters, I've replaced the knobs, and I've replace the box all the igniters and plugged into. There's nothing else to change out and it still doesn't give a spark. I've got gas and electricity but nothing will light
2helpful
2answers
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
1helpful
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
2helpful
Gas stove with a electronic igniter
You got things wet that don't like to be wet. Once it drys out it should work fine
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
