No point contacting contacting airtel customer care, because your SIM card is working perfectly on different phone so I'd suggest you to reset your mobile phone once, that can fix the problem for you. If the issue is same, take your mobile phone to nearest Nokia service center.
hi...
there is button below the volume key. Consider if u have airtel and idea card in ur mobile, if ur mobile shows idea is selected and u want to call from airtel then press the button. it will change the network and u make a call from airtel.
Dear Anand
Welcome to Fixya Support.
Generally Micromax mmx 310g USB modem is mainly designed for BSNL sim and it has inbuilt Network Code Key(NCK) of BSNL. So for installation of any other Network Code key you have to contact network operators(Vodafone,Airtel,Aircel )and they will generate Network Code key for your device.
I think it helps. Let me know
For Airtel gprs settings in blackberry handset follow the steps :
Press the menu key
Then select options.
Then select advanced options.
Then select TCP.
Then you will find APN and in APN you need enter airtelgprs.com(Type airtelgprs.com everything in small letters,without leaving any space in between) ,and leave username and password blank.
After doing the settings press the menu key and press save.
After doing the settings you also need to activ the gprs services from the service provider to use the gprs service.
go to settings .. phone settings .. thn operators selection ... manual ... and u check the network ... and see if airtel is available in ur loacality .... if availble .. th ni twuld work ....
download internet settings from airtel. then istall them, Then goto settings, internet setting there select airtel profile and switch off and on your mobile. now you can use the internet.
