Wont get past the first screen. F8 does not work nor comes up any repair selections. Ctrl and F11 do not work and f9 does not work. How do i do the factory settings restore from start up as i can not get into the computer, i do not have any disks and can not get any. HELP PLEASE!!! My old toshiba was easy hit 2 buttons reset it all and done. Now the dell i can not work out and nothing i have looked up is working at all.
What if you press F8, select "Repair Your Computer" and it doesn't work or your computer simply reboots?? Here's what worked for me.
1) Download Hiren's Boot Cd (IT'S FREE) (hirensbootcd.org/download).
2) Burn the downloaded iso file to a blank DVD.
3) Bootup your laptop using the Hiren's boot cd/dvd.
4) From Hiren's boot cd menu select "Mini Windows XP".
5) From Mini Windows XP select "Command prompt".
6) In the command prompt window, type "d:" and press enter.
7) Still in the command prompt window, type "cd\tools" and press enter.
8) Finally, type "imagex /apply d:\dell\image\factory.wim 1 c:\" and press enter.
9) WARNING when you press enter you will completely wipe your c drive.
10) When complete, reboot your computer, should come up with factory settings.
Resetting
a Dell Inspiron to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Get the step-by-step how to guide..http://technical-support-squad.blogspot.in/2012/08/dell-inspiron-how-to-factory-reset.html
SOURCE: dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
SOURCE: I want to restore my dell inspiron 8600 to factory
Use the simplest way to reinstall the computer to the factory settings
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
SOURCE: how can i restore my inspiron 1521
if your running Windows Vista you can try this
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R143625&SystemID=INS_PNT_PM_1521&servicetag=&os=WLH&osl=en&deviceid=3601&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=7&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=191736
That's an Image File that re-installs windows onto your machine, just make sure you read the instructions if.when you use it :-).
