Vizio VO320E LCD TV Logo
Posted on Aug 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio screen problem. Please help!
I have a vizio model number vo320e. When I power on I get 3 bars of color. The top is dark blue where you can see the picture. The Middle bar is light blue and cuts off the picture. The bottom bar is gray and has no picture. The middle light blue blinks on and off. There are also verticle whitle lines running through the light blue and gray area. Is the screen bad or can this be fixed? Thanks.
Lawrence Oravetz
Level 3:
  • Vizio Master 10,558 Answers
  • Posted on Aug 13, 2017
Lawrence Oravetz
Vizio Master
Level 3:
Answers
10558
Questions
Helped
2695762
Points
29284
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
4 Related Answers
Anonymous
  • 1139 Answers
  • Posted on Jun 17, 2009
SOURCE: vizio 47" sv470xvt1a 6" wide verticle green bar on screen
Hello ,
I would suggest checking the driver circuitry for the LCD screen and I would also check the connectors from the driver board to the LCD. Either a component has begun to malfunction (hence the excessive heat) or the component has becom thermally sensitive and is reacting to existing heat and is allowwing excessive current to pass causing more heat to be generated. In any event have a qualified TV technician look at this problem because he will have the proper equipment to troubleshoot the TV in the proper fashion.
Anonymous
  • 125 Answers
  • Posted on Oct 21, 2009
SOURCE: Vizio 32'' VO320E Image Distortion
I hope not but:
this is probably a failure from the screen or the electronic parts that control the videosignals.
i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
Hope this is helpful, and greetings,
Olivier.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 28, 2009
SOURCE: I ave a two year old Vizio VX37L that now only
The problem is the LCD panel itself is bad, but you can also try replacing LCD controller first but doubt very much to be that. You can also try cooling the back of the LCD panel (on the top section) to see if the problem will go away, I had some luck installing a small cooling fan behind the LCD panel. Run the TV with the back open with a fan running in the back.
CoppellTVRepair.com
  • 778 Answers
  • Posted on Oct 31, 2010
SOURCE: vizio p50hdtv10a no picture, gray screen
This could be several things. It could be the main board 3850-0042-0150 or the plasma controller board 6871QCH083A.
Depending on what you actually see on the screen it may as well be bad Y sustain board (although less likely).
Unless someone has seen that particular issue in that particular model (or other that share the same deffective component) it will be anyone's guess which is the exact module. They all can be causing what you describe.
Since TV shuts itself in one minute I'm leaning towards the main board.
I'm afraid you'd have to either experiment or bring it to a service center that will either have such a TV and can try or will experiment on your behalf. Just make sure you do not pay for boards they experiment with. I know some of the other TV service shops in our area (and without a doubt elsewhere too) do that.
A TV service center (just as anyone with regular contacts with eBay) can resell incorrectly ordered part and end up losing $10-$20 on it which , if split between customer and technician, I think is completely fair. Just make sure you don't end up paying for a board that was ordered and turned up not the one in fault.
bobby
www.coppelltvrepair.com
Vizio D43N-E1 LED TV red/blue color horizontal bars
Unfortunately, this sounds like a panel issue
1helpful
How do I fix my Vizio Model VX37L HDTV10A distorted colors
its time for another Tv set man
the screen gone bad
Vizio 39 inch power light stay on dark screen
Hey, could be many things, sounds like a main board problem if can not turn off with remote or buttons on set if any some new sets have to have remote. Need model number and age to help but if main can google part number off of board itself take back off it is the one with the cable hookups on it and see what it cost. One site is www.shopjimmy.com and try it. Good luck
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
I have my Vizio vo320E TV hooked up to my cable box. and it says no signal. What must I do to fix this problem. Thanks Jay
you must not have the cables right. try again. I am using a HDMI cable and it works fine. The 3 color cables---not so much
2helpful
2answers
Missing screws for detachable stand for Vizio VO320E. How can I find replacement screws?
To get the details of exact size of these screws, you should download its repair manual. The disassemble section of that manual will have all these details. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
How to download manual for model E329-A1
Check your model number. There appears to be no Vizio with that number. If it is a E320-A1, here's the manual: http://store.vizio.com/vo320e.html under the support button.
Vizio half of screen is solid color bars. Top half works great.
You have either the circuit board that drives that half of the screen(one for top and another for the bottom) or you have a bad display panel.
7helpful
2answers
No power to tv after power outage
The power boards go bad alot in vizio's, Most likely 4 bad cap's need to be replaced, $10 in parts,,
I hope not but:
Olivier.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
