Question about Apple iPad 32 GB 3G Tablet PC
I dnt remember my prepaid number for my ipad - Apple iPad 32 GB 3G Tablet PC
How do you unlock the Activation Lock on an ipad when you don't know required Apple id or Password
Your apple ID is normally your email and use the FORGOT PASSWORD line they will send a reset to your backup number or email address
Aug 18, 2017 | Apple Tablets & eReaders
I appear to have locked my ipad how do i unlock it lock off my ipad
if you remember the password then slide to unlock or else if u dont remember it you have to put it in to dfu mode and then restore it with itunes. make sure you have backed up your ipad.
Feb 15, 2015 | Apple iPad Tablets & eReaders
How do I transfer apps and files to SD card
You cannot transfer apps to an SD card unless it is jailbroken. I don't recommend doing that, but you can transfer pictures if you have a camera connection kit. You can also transfer movies to your iPad if you have it formatted in MP4 format and the file name is changed to something like 1234abcd. It has to be 4 consecutive numbers and 4 consecutive letters. Like 6789efjk. I don't believe or remember off hand if the letters or numbers have to come first, but there is plenty of documentation on the web.
In regards to apps and files, you must use the connection cable from your computer running iTunes and your iPad to backup or transfer files and apps. In iTunes, there will be a list that shows you the files you have on your iPad if they are transferable. There is a lot of documentation on the web as well for that too! I hope I helped you some.
Feb 03, 2015 | Tablets & eReaders
My ipad is locked how can i fix it
You have setup an iTunes account with Apple. When you connect the iPad to iTunes, (WiFi or via computer) they ask you the password for your iTunes account. If you forgot that one, Apple can send you an reset code to the mail address connected to the Apple account. (Not the iCloud mail)
If nothing works, goto the closest Apple store and take your invoice with you and an ID card, to prove you are the legal owner, perhaps they can help you.
Jan 02, 2015 | Apple iPad 2
How do I use my I-Pad when I don't remember the Password anymore?
You can connect your ipad to itunes... in recovery mode... switch off the ipad and then turn it on with holding the power button and the home button simultaneously untill you find itunes symbol on your ipad screen... then select restore in itunes... Remember it'll wipe all your personal data... but you can access your ipad again.
Dec 16, 2014 | Apple iPad Tablets & eReaders
How do I determine what generation is my iPad?
on the backside of the iPad is a model number: determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-0.jpg determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Model iPad (1st generation) iPad 2 iPad (3rd generation) iPad (4th generation) iPad Air iPad Air 2 Picture 200px-ipad_1_psd_mockup.png 200px-ipad_3.png 200px-ipad_3.png 200px-ipad_3.png 170px-ipad_air.png 170px-ipad_air_2.png Model Number[99] A1219 (Wi-Fi)
A1337 (Wi-Fi + 3G) A1395 (Wi-Fi)
A1396 (GSM model)
A1397 (CDMA model) A1416 (Wi-Fi)
A1403 (Wi-Fi + Cellular (VZ))
A1430 (Wi-Fi + Cellular) A1458 (Wi-Fi)
A1460 (Wi-Fi + Cellular (MM))
A1459 (Wi-Fi + Cellular) A1474 (Wi-Fi)
A1475 (Wi-Fi + Cellular) A1566 (Wi-Fi)
A1567 (Wi-Fi + Cellular How to find iPad IMEI ICCID serial number
http://en.wikipedia.org/wiki/List_of_iOS_devices#iPad
Sep 21, 2014 | Apple iPad Tablets & eReaders
My son has put a passcode on my iPad how d I remove it cz dnt know passcode
Interesting question, I looed it up because my memory is so bad I'm likely to forget mine! I only pass coded it to keep the grandkids off it!
See link for instructions from Apple iOS Forgotten passcode or device disabled after entering wrong passcode
Sep 12, 2014 | Tablets & eReaders
I need a number that can help me un disable my ipad
If you cannot remember the pass code you will need to restore iPad through iTunes. You must put the iPad in dfu mode to restore, there are several videos on YouTube on how to put your device in dfu mode. After it is I dfu mode, simply plug device into iTunes. iTunes will detect that the device is in recovery mode and give you the option to restore..
Mar 24, 2014 | Apple iPad Tablets & eReaders
I cant remember my ipad password and i have tried everything what do i do?
1. Boot iPad into recovery mode (You can find instructions online that explain this specifically)
2. Connect your iPad to your computer and open iTunes
3. Restore your iPad from previous backup
Nov 08, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad 32 GB 3G Tablet PC Logo
22 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
