Question about KitchenAid Artisan Series Tilt-Head Stand Mixer
Kitchenaid Mixer head wobbles bad
HI,
I am getting a kitchenaid from someone and they said they bought a new one cause the mixer head wobbles. They said kitchenaid said it was an adjustment problem. I know there is a screw underneath that holds the hinge pin and it should try to be tightened first. She said she tried some things but...............................................
She said it wobbles so much it took off some of the plastic coating of the paddle attachement because it got rubbed off from scraping the side of the bowl.
Is there another thing that can be checked myself to try to adjust this so it won't wobble?
  • bsiebert1 Dec 06, 2008
    Same problem ... bugs my wife more then me. 2 pounds of butter rotating seems like it would cause some balance issues.
    But an answer would be helpful.
  • avariale Dec 19, 2008
    kitchaid mixer head wobbles. tied to adjust the screw under on the hinge, but it still wobbles.
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Posted on May 24, 2009
I have had the same issue in the past and had to buy a new paddle because the coating had worn off in one spot. The Customer Service representative told me how to adjust the paddle at that time, but I had forgotten.
It is now starting to do the same thing, so I call Kitchenaid again, and they gave me the fix once again. This time I'm keeping it in my files. I suggest you do the same. Here it is:
To balance paddle, put a dime inside the bowl with the paddle on stir speed. If well balanced the paddle should nudge the dime as it turns. If it drags the dime, tilt the head back adjust the screw inside the head of the mixer one-quarter turn to the left.
Posted on Jan 30, 2009
  • JayM Nov 22, 2011
    I had the same problem as Ihairdo above - a wobble in the head of the mixer and subsequent rubbing of the paddle on the side of the bowl. The directions for adustment from both tulanebme and luannej worked perfectly. Thank you. I also added some thread locker to the threads of both screws (a small tube can be had at any hardware store for about $5 - Loctite is one brand) to prevent the screws from moving in the future. It has been about 6 months - so far so good. Thanks again!
6ya staff
SOURCE:
How do I fix a wobbly head on my Kitchenaid Epicurean stand mixer?
Tip it upside down on a towel and tighten up the hinge retaining screw right up inside the pedestal.
Jun 30, 2013 | KitchenAid Food Mixers
My kitchenaid stand mixer arm wobbles when I turn it on.
if the head wobbles on stand, flip mixer upside down, and tighten the pivot pin screw way deep down inside stand. you will need a long flat blade screwdriver. it's probably loose.
May 13, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer is a lift-top and the top seems to be loose and wobbles as it mixes. help?
Hi, W/D here.
If you raise the head of your mixer, and look under the raised part, you'll see a silver screw head with a slot for a standard bladed screwdriver. Tighten that screw, and that should do it.
Best regards, --W/D--
please feel free to rate this solution!
Jan 31, 2011 | KitchenAid 32685 Mixer
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Mixer Head Wobbles
Fixed it!!! My mixer had the same problem.  It was a hand-me-down...
Okay, so I lifted the head and looked down into the pivot where there is a screw (looking from the front of the mixer).  I took a flat-heat screwdriver and turned it counter-clockwise.  (It took quite a few turns, the screw came out a few millimeters.)
BUT when I lowered the head, hurray!  No more paddle rubbing against the bowl!  No more head jumping up and down!  No more wobbling in the "locked" position!
Try it!
Jan 13, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid wobbles when mixing
Do not store or transport the mixer on its side ever. Always upright. The grease in the gearbox should even out eventually. Try sitting on it when it wobbles. At least yours works.
Dec 26, 2008 | KitchenAid KSM150PS Artisan Series Stand...
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Dec 14, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer head wobbles
is it the mixer head or is it the beater paddle? i will need to know which one it is.
Oct 29, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
KitchenAid Artisan Series Tilt-Head Stand Mixer Logo
14,932 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
