My Whirlpool AWM5080 leaks a small amount of water after each spin sycle.I've tried to locate the source but looking under one of these machines isn't easy. I've made sure the machine is stable and I don't use too much powder. Any suggestions?
Try taking the back panel off of the machine, (make sure its unplugged first) under the drum you will see a short black rubber hose with jubilee type clips holding it on, it may have come loose during a spin, you will need a different type of screwdriver to undo it, like a hexagon type, hope that helps!
HI i have the same Whirlpool model AWM 5080 and I have the exact same problem, did you find the casue to the problem?
Cheers
Scott
Water leaking under machine on spin cycle
