SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
SOURCE: Need a pert for flat panel television
ebay is your best bet,
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
SOURCE: I'm trying to source a
your best bet is probably SONY parts Dept. you can reach them by phone at: 1-800-488-SONY (7669).
or on the web at:
Sony Parts & Accessories
FYI I couldn't find your part on the web site. I recomend you call.
SOURCE: I have a 42 in. Vizio Galleria and need to remove
1. Unplug all of the cables and cords from your GV42L
FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and
flat surface (blanket, foam, cloth, etc) to prevent any
damage to the TV.
3. Pull the stand cover off by squeezing the sides to
release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws
(screw's specs: M4, 0.7 Pitch,
15mm long) so that the stand
base can be removed.
5. Gently remove the stand
base
6. Now, the GV42L FHDTV10A can fit securely to a
mount (sold separately) by utilizing the mounting
holes in the center of the back panel of the TV.
Please make sure to read the instructions of your
specific mount to properly hang the GV42L
FHDTV10A
