Re: Whirlpool Ultimate Care Heavy Duty Super Capacity Plus 8 Cycle 2 Speed Motor
Hi! I'm unsure of the model number of this machine, first of all. It was purchased in 1997 (+/-). Everything is fine with my machine, except it just stopped draining the water with the last spin cycle. Thus, clothes are sopping wet when ready to go into the dryer. I'm still trying to decipher whether or not the second speed of the motor is functioning or not. Just guessing here. The center rotating piece is turning as normal with the first part of the cycle.
Any helpful advice would be appreciated. Thanks, in advance, for your help!
Sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
