Convert to multi-region please
SOURCE: how to convert my Panasonic DMR -E30 dvd recorder from uk region to multi region format
Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
and here are some other HACKS for your players
like Macrovision bypass ISCSI BAYPASS ETC
http://www.videohelp.com/dvdhacks/panasonic-dmr-e30/1585
SOURCE: Zenith ZHX-313 DVD/Video Player
I also have this model and it took me a long time to find the solution. It turns out this model is actually an LG.
If you use the instructions for an lg-6000, it worked for me.
Here is a thread I found on another site:
I found a website (http://lgregionfree.tripod.com/) that has a different CD image for LG 6000 series players. I tried that and it works, my player is now set to region 0 and has played region 1, 2 and 4 discs.
Here is the process:
1) Download http://lgregionfree.tripod.com/6000.zip
2) Extract the ZIP file, which contains a Readme file and a directory named RMTM0000
3) Using a CD burning program, burn the RMTM0000 directory to a CDR, making sure to use the ISO9660 file system instead of the default Joliet. Finalize the disc.
3) Turn on the player and insert the disc. The Region Test Menu screen should appear.
4) On the remote, press your desired region (or 0 for regionfree), then press Enter then Pause.
5) Eject the CDR and turn the player off.
6) Turn the player back on and enjoy.
NOTES:
a) I did not need to wait a minute between region selection and pause.
b) On some players this hack causes the buttons on the player itself (not the remote) to stop working. I can confirm that on the XBV443 the player buttons continue to work.
SOURCE: Hack wanted to enable multi region
1) Go to the Preference page in the Setup menu
2) Press 1 3 8 9 3 1 on the keypad of the RC. I had to hold each number down for 2 or 3 seconds.
3) Options will be available to be selected. Select 0 using up/down on remote.
4) Player is now region free.
SOURCE: convert to o multi-region
SOURCE: Denon DVD 2200 - region change?
read ur insrucion book and it will tell u what to do,,,,if not go in contact with denon
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
