Question about Behringer XENYX 2442FX Mixer
What is the Ohm value of the sliders. i have Behringer 2442fx yenyx mixer
    New Friend:
  • 4 Answers
Faders are 10 K
Posted on May 18, 2012
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: behringer xenyx 2442fx : I need to know the
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Posted on Feb 13, 2011
Testimonial: "Really great help ! Thanks once more !"
Fred Yearian
  • 5603 Answers
SOURCE: Behringer XENYX 2442FX Mixer. The power light
You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
Posted on Nov 06, 2010
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: how do i hook up a powered moniter to the
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Posted on Nov 30, 2010
nileshsingh2
Nilesh Singh
  • 246 Answers
SOURCE: pluggin headphones into my behringer 2442fx mixer
This happens when you have lose earth connection from your main source power supply. Check the earth connections (grounding) which should be available in the mixer, i.e some power cords don;t have earth wire, so change this if you think yours don't have it. Also check the grounding of the other items attached to your mixer, basically grounding is very important to reduce the static shorts. Try changing the power supply source, change to other outlet and check if it is OK.
Posted on Apr 14, 2011
mrwtech727
mrwtech727
  • 75 Answers
SOURCE: how to connect a Behringer XENYX 2442FX Mixer to a
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Posted on Sep 01, 2011
How to connect a Behringer XENYX 2442FX Mixer to a laptop
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
My Behringer Xenyx 2442Fx does not get power.I have checked the power cable also.Kindly help me out
The switching power supply has probably failed. See if you can get a number off the power supply board like SPS400 or similar. Unless you are electronically adept this is lkely NOT a DIY repair.
Jul 26, 2011 | Behringer XENYX 2442FX Mixer
Pluggin headphones into my behringer 2442fx mixer is creating a lot of static coming out of the headphones.
Apr 14, 2011 | Behringer XENYX 2442FX Mixer
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
Nov 20, 2010 | Behringer XENYX 2442FX Mixer
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
Oct 19, 2010 | Behringer XENYX 2442FX Mixer
How do I adjust the volume when I plug my mp3 player in to the phonos with out the main slider
In a word, you DON'T... The main fader is the ONLY volume control in the loop going into the TAPE inputs.
If you need another volume control, then either use volume control if availlable on the tape/MP3 player.
Your other option is to use a splitter cable from the MP3 into one of the stereo input channels which do have level controls.
Now if you want to have the tape input level INDEPENDENT of the main slider, that is not really possible either. Adding a mixer AFTER the mains could accomplish this, but that is extra hardware.
Aug 06, 2010 | Behringer XENYX 2442FX Mixer
Behringer XENYX 2442FX Mixer Logo
115 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
