Screen resolution won't go higher than 1024x768 and the auto image adjust option is greyed out
Jagdish hyjacks, Miriam
ok
NO PC stated at all so any exact answers will be weak or wrong.
the auto image feature centers the display .
if your PC is set to a resolution that is wrong or near perfect
this features shows grayed out,
the gray means.:
1:; IT's as good as I could make it at power on.
2: the input video is not fully supported on the monitor.
the list is in your manual if you care to read it.
1920 x 1200 @ 60 Hz (best and natural )
1680 x 1050 @ 60, 75 Hz
1600 x 1200 @ 60 Hz
1400 x 1050 @ 60, 75 Hz
1280 x 1024 @ 60, 70, 72 Hz
1024 x 768 @ 60, 70, 75, 85 Hz
800 x 600 @ 56, 60, 72, 75, 85 Hz
640 x 480 @ 60, 75, 85 Hz
720 x 400 @ 70 Hz
any other setup at the PC may cause the monitor to fail
or not allow all features seen in the OSD.
ok?
no monitor made in earth can do all resolutions invented from 1981 to 2018 , not yet, nor not really needed. or too costly.!
so set the PC to 1920x1200 and end this.
Only blink auto adjust image plz help mi
6 years late?
SOURCE: Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
SOURCE: Do you know where I can get a power supply for a
http://www.discount-merchant.com/VIEWSONIC-2950149205-p/1173574.htm
I was also looking for one and found it here
