On this website you find fuse box diagram and description for Cadillac Escalade mk2 (2005)
Cadillac Escalade mk2 Second Generation 2005 fuse box diagram Auto Genius
SOURCE: where is the fuse box in a 2005 sts cadillac
one under the hood one on the drivers side of the dash
SOURCE: the service ride control button appears on my 2005
You must have a leak in your air ride suspension, Going to need a scanner to diagnose where the problem is.
SOURCE: What does it mean when the Service Ride Control
THERES A PROBLEM WITH THE AIR RIDE, THE AIR BAGS,,,,,,,, CHECK UNDER FOR DEFECTS OR OUT OD ADJUSTMENT, MOST OF THE TIME YOU DONT RELIAZE BUT PEOPLE RUN OVER STUFF ON THE ROAD AND DAMAGE A PART OR THE LEVELING SENSOR
SOURCE: cadillac escalade ext will not start dic message
A battery can read 12 volts yet be weak in cold cranking amps, try a jumpstart and if that works have your battery load tested. Im betting your gonna find the battery fails the load test, meaning it needs to be replaced..
