Question about Cobra 2-WAY COMMUNICATOR 2-Way Radio
Musical symbol displayed on the screen
One of my radio's is not compatable with the others, on the screen there is a musical symbol, how do i remove this symbol?
  • 111 Answers
What`s the model #
Posted on Aug 19, 2006
6ya staff
SOURCE:
Does evlipse mp3 have bluetooth?
The Essentials
  • 2.8" Touch Screen Display
  • 8GB Storage
  • Bluetooth® Enabled
  • Plays Music, Videos and Pictures
  • Pedometer
  • FM Radio
  • Built-in Rear-Facing Camera
  • Compatible with MP3 Downloads from iTunes
..this is what I found on the net.
Nov 08, 2016 | Audio Players & Recorders
How to set the clock on a 2008 chevy cobalt
Setting the Clock (H-clock symbol, O-pwr symbol, f-music note symbol)
Without Date Display
AM/FM Base Radio with a Single CD Player
This type of radio has a
H
button for setting the time.
You can set the time by following these steps:
1. Turn the ignition key to ACC/ACCESSORY or
ON/RUN. Press the
O
knob, located in the
center of the radio, to turn the radio on.
2. Press the
H
button until the hour begins flashing
on the display. Press the button a second time and
the minute begins flashing on the display.
3. While either the hour or the minute numbers are
flashing, turn the
f
knob, located on the upper
right side of the radio, clockwise or counterclockwise
to increase or decrease the time.
4. Press the
H
button again until the clock display
stops flashing to set the currently displayed time;
otherwise, the flashing stops after five seconds and
the current time displayed is automatically set.
To change the time default setting from 12 hour to
24 hour, press the
H
button and then the pushbutton
located under the forward arrow label. Once the
time 12H and 24H are displayed, press the pushbutton
located under the desired option to select the default.
Press the
H
button again to apply the selected default,
or let the screen time out
Dec 27, 2014 | 2008 Chevrolet Cobalt
The radio on my new dodge ram is locked on the startup screen....the screen with the ram symbol and Sirius xm logo bellow it. Cannot find out how to reset it! Does anyone know how to reset this radio?
Try removing the - negative - black battery terminal for at least 5 minutes then reconnect it. NOTE All of your preset radio stations clock and other settings will also be reset. Check your owners manual for more information.
Sep 25, 2014 | Audio Players & Recorders
I have a rca clock and by error the time is set to wake me up how can I cancel this?The model RC46-B
Hello
To disable the wake up function completely; Press [Bell Symbol] [Music Symbol] & press '1' of '2' repeatedly unti no wake mode ikon [1-bell symbol, 1 music symbol or 2-bell symbol 2 music symbol] shows on large display. I can't include these symbols with this site, as I give you the details of the symbols.
You can download the manual of your Clock from the following website.
static.highspeedbackbone.net/pdf/RC46_DOC_Manual.pdf OK.
Jul 14, 2011 | RCA Audio Players & Recorders
How do i get the channels to change on vx10 radio selector does not seem to change them radio recently repaired by yaesu and user manual not much help
The dial is probably locked. Look for a little padlock symbol on the display. Check the user manual for Dial or keyboard lock. Generally on Yaesu radios you use the function key plus a keyboard key. If the keyboard is labeled, you should see something that looks like a padlock next to the correct function key.
Feb 11, 2010 | Vertex Yaesu Radio FTH2009, FTH7009...
How to send a picture via bluetooth
in LG type phones, this actually easy.. first the easy part is to activate your bluetooth. check also your settings and your bluetooth name for you to know your device. if it is a phone to phone transmission, both must be activated. choose the picture but notice a bluetooth symbol on top of your screen usually beside the clock should be activated or moving. go to options then choose send.. there will be choices like infrared, bluetooth, etc. of course, choose bluetooth. it will re access and prompt the you and the receiver the bluetooth detected. then done.
Jul 08, 2009 | LG RUMOR Cellular Phone
Radio will not transmit, display seems wrong
Here is a link to the user manual for the SV600R. http://www.giantintl.com/ContentManage/manuals/Moto/SX600%2012-21-07.pdf Follow the instructions to reprogram the affected radio. Note: The problem you are describing may not be simply programming. The radio problem may be non-reversible. You might also try a new battery, or switch the battery from the other unit for a test, just to see if the battery is bad.
Jun 07, 2009 | Motorola SX600R Two Way Radio
Can't get the Video 1 symbol off of my TV.
There is a button on the remote labeled display that must be hit to remove the on screen display. You can use any Sony TV remote so you may want to check out GoodWill for a used one. Sony also has a universal available but it may be hard to find, maybe Radio Shack. There is no other way of turning off the OSD.
Dec 21, 2008 | Sony KV-27S46 27" TV
Motorola T6550 pair.
I can see where this feature can seem somewhat inconsistent. But if you think of it like a phone ringing, it is easier to understand. Once you have answered the phone, the phone stops ringing. And the person who called you never experiences a ring on their end.
VibraCall® Alert
Page 26: VibraCall is a vibrating alert that notifies you that your radio is receiving a message. This is useful in noisy environments. When the alert is on, the radio
vibrates once every 30 seconds when you receive a message on the channel and
code you set.
• To turn vibrating alerts on, press menu until the vibrating radio symbol is displayed, then press the plus (+) button to display the letter Y for Yes.
• To turn vibrating alerts off, press menu until the vibrating radio symbol is displayed, then press the minus (-) button until the minus symbol (-) is displayed.
Dec 10, 2008 | Motorola Talkabout T6550 (7 Channels)...
Cobra 2-WAY COMMUNICATOR 2-Way Radio Logo
60 people viewed this question
Top Cobra Radio Communications Experts
Chris
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
