Televison & Video Logo
Posted on Oct 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Siny Trinitron G21M1 is producing horizontal lines across the screen
The picture quality has deteriorated it is becomoming more of a black and white TV insread of color. It produces horizontal lines across the screen
  • bndubs Oct 27, 2008
    welcomejee,
    I acknowledge your response and the answer to your question is I am a learner computer technician can you please assist me with how to fix this problem on my Sony KV-G21M1 .
    bndubs
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Oct 26, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957094
Points
33084
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
  • Muhammad Gazzar
    Muhammad Gazzar Jan 21, 2016
    i had same problem and i know how to get instructions and repair .. so what shall i do to fix this problem in this model ?!
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
1helpful
2answers
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
2answers
Sony Trinitron 21 inch KV-G21M1
Hi there!
Sounds like a power supply fault. You could try replacing all capacitors in the power supply and others areas around the line stage, with the same values. You may also want to check the tuner or "IF" circuit for dry joints. Hope this will help you. Kind Regards, JUS004
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
6helpful
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
1helpful
My pictures and the lcd screen come out blurry and pink, with horizontal lines across
What model camera do you have? A few years ago a large number of defective Sony CCD's were installed in many cameras from several vendors. The CCD's eventually deteriorate to produce the effects that you're seeing. If your camera is a Canon, there's a very good chance that Canon will fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jul 12, 2008 • Cameras
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
32" Trinitron warms up picture goes black
You need to call for service now that the unit still turns on,the problem will become expensive if you try to use it like this,right now the set might have loose conections in the power supply,horizontal driver transformer.ETC.Be safe and call a service tech.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
