A blurred screen on the right-hand side of a Blaupunkt TV for about 2 inches from top to bottom can be caused by a few different issues, such as:
A problem with the display panel: The display panel may have become damaged or malfunctioned, causing the blur on the right-hand side of the screen.
A problem with the T-CON board: The T-CON board controls the video signal between the main board and the display panel. If it is not working properly, it can cause the blur on the right-hand side of the screen.
A problem with the main board: The main board controls the various functions of the TV. If it is not working properly, it can cause the blur on the right-hand side of the screen.
A problem with the cable or connector: Damaged or loose cable or connector can cause the blur on the right-hand side of the screen.
It's best to consult the manual or a professional technician for help. They will be able to diagnose the problem and recommend the appropriate course of action. Sometimes, the problem can be solved by replacing a faulty module, repairing or replacing damaged cable or connector, but in some cases the repair may be more complex and require more extensive work.
Sounds like somebody put a nasty virus on your Pc known as Windows 8. Ha just kidding but it is lousy. I run Linux Mint so I don't have to deal with such junk. At the Microsoft Community others are talking about your issue , maybe you can get some answers there. Good Luck. want to disable the charm screen from popups
what's the model number and what's happening with it,do you mean the fridge is on top and freezer on bottom?open the fridge door,look up on right hand side up near ceiling and send the model number and the first two numbers of the serial number
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Insofar as your Ignition Wiring Diagram, I hope you're speaking of what's also called the Spark Plug Cables or Firing Order. The proper Firing order for your V-6 is 1-5-3-6-2-4 with the number 1 cylinder being the front spark plug on the left hand side. The left hand side is Odd numbered and the Right hand side is Even numbered, therefore number 2 cylinder is the 1st plug on the right hand side of the engine.
General reset procedure for DM tech is:
1. Have Analogue station showing,
2. Press display button on remote,
3. With display info panel in view on screen, press 1 1 Line buttons on remote, this should bring up reset menu on left hand side of screen.
4. use up/down arrow buttons on remote to select either Reset or EEPROM then use right arrow button on remote to select the appropriate procedure
NB - on my set, selecting OFF the annoying melody that plays when the TV is turned ON/OFF diasbles Digital TV (Freeview). Turning ON the annoying melody makes DigiTV work again!
if it is anythang like the 2002 eclipse gt stereo there is 2 button on the right side of the display screen hold the right one down and it will change the mins and the other 1 will change the hours
Attention barrbunchMy model is TC=32LX60. We have tried everything to get rid of it. We must of hit a button by mistake.
Rrosemary
