some TomTom models do not have enough space to store all the possible maps you can download. You will probably have to remove your current map in order to install the Florida map. The TomTom utilities should tell you how much is need/available.
You may be able to get "free" map updates from (illegal) underground sources. But that's not recommended. Yes, you're right, you can simply get a new TomTom GPS and get the latest map(s) for it. Consider getting a TomTom with lifetime maps ....and you won't have to pay for any map updates.
Tom do not seem to overwrite the existing map file. So before trying to install the map, you need to delete the folder that contains the map. (It is important to read the next part before you delete the map folder).Once you have connected your TomTom to the computer, close the TomTom home window. Double click on my computer. You will see the TomTom hard drive as a drive (like you see the CD drive). Double click on that . Once the folders of the TomTom hard drive opens, look for a folder named USA_Canada_and_Mexico_P. (Please note: this name is for American continent. For others, this name will be different). Right click on it. click properties. Check whether the size of this folder is approximately around 1.3 GB to 1.5 GB. This is just to make sure we have the correct folder. After confirming this is the map folder, copy this folder to your computer for back up purpose. Once you have it safely in your computer, delete this folder from the TomTom hardrive. Go back to TomTom homesoftware. Use the map guarantee to update/Upgrade the new map. You will see this time around the installation completes without a problem.
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
There is no solution, and the manufacturer is not amenable to any news of this.
It used to be possible to remove the mapsettings.cfg file from the TomTom unit's maps before downloading and installing a new map, then to replace the file; however, TomTom changed the coding on the latest maps so that the software no longer recognises the old cfg file. There is a complex workaround where you change your favorites, one by one, into Points of Interest - but it seems pointless having a Favorites item when you have to do this.
SOUNDS LIKE YOU DOWNLOADED IT TO TOM TOM HOME AND NOT TOM TOM ITSELF. OPEN UP TOM TOM HOME AND LOCATE THE US MAPS THEN THERE SOULD BE A OPTION TO TRANSFER MAP TO TOM TOM.
I HAVE ALSO 910 TOM TOM AND A PRO AT TOM TOM DEVICES
