RobC Posted on Feb 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My paper all of a sudden keeps getting jammed in my mfc780 any help would be nice
Harvey Mahal
Level 2:
New Friend:
  • Expert 39 Answers
  • Posted on Feb 19, 2012
Harvey Mahal
Expert
Level 2:
New Friend:
Answers
39
Questions
5
Helped
10332
Points
118
Clean the spung roller with rubbing alcohol.
5 Related Answers
Anonymous
  • 178 Answers
  • Posted on Feb 13, 2008
SOURCE: Dell 3000cn Laser Printer Problem--Paper Jam
Hello how are you Take the tray out on the bottom and see if there is a piece of something in there. Mine does this sometimes. Also on the back there is a drawer open this up and check. Have you taken out the toner yet. Do this and once you check every area as described turn power off to it and leave off for min. Then power back on and push cancel button about 5 times let me know if this works for you. It does for me
Anonymous
  • 158 Answers
  • Posted on Jun 09, 2008
SOURCE: False Paper Jam Message
Probably a jam sensor is dirty or stuck. Look through the paper path for a stuck plastic sensor arm, or dirt or paper dust on photocell typr sensors.Paper sensors are normally located near where paper feeds, and where it exits the machine. The paper must pass over these sensors as it travels through the machine.If a scrap of paper is left on the sensors, they will report it as a jam. If you can, try manually pushing a sheet of paper through the printer, ONLY in the direction it normally feeds. This may free up a stuck sensor arm, or force out the jammed scrap.
Anonymous
  • Posted on Sep 26, 2008
SOURCE: Lexmark X73 paper jam
please solve my problem
Anonymous
  • 34 Answers
  • Posted on Mar 14, 2009
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
electronacs
electronacs
  • 19 Answers
  • Posted on Jul 07, 2009
SOURCE: Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
How do I fix paper jam for AV122C
Sounds like the machine is picking up a signal from the paper exit sensor. The flag is not moving freely, or not moving at all. Look down in the paper hopper, ( where the paper is loaded), you might be able to see the sensor. The flag is spring loaded. Sometimes the flag falls off. The flag is black and shaped like a (T).
1helpful
Printer does not feed paper and display keeps saying paper jam
This is most likely cause by a paper jam in the printer. Simply open the printer up and remove and paper jams then reassemble the computer. I hope this helps and have a nice day!
1helpful
HP PSC 1610 - Keep getting paper jam error with no paper jam.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
AFICIO SP C410DN BRAND NEW OUT OF BOX. PAPER JAMMING COMING OUT OF PAPER TRAY AND BYPASS.
There are several steps involved in unpacking your particular color printer.
I'm sure you have the quick start guide which provides very nice photographs of how to remove the packing tape and materials within the printer, but just in case:
http://www.ricoh-usa.com/downloads/manuals/printers/c410dn/manuals/Quick_Installation_Guide.pdf
I hope this helps.
In the odd case that everything is clear and you still get paper jams, take it back and have it replaced before your 30-day or whatever exchange warranty runs out.
Good luck. Keep us informed.
6helpful
2answers
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
1helpful
Paper keeps getting stuck in printer HP Deskjet D1470
Are you using quality paper? While it's nice to buy the cheaper paper, it will cause jams. Make sure you buy the correct paper for your printer by checking your manual. It doesn't have to be HP paper, just make sure it's the correct weight.
2answers
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
k24674
ADMIN Andrew
ADMIN Andrew
