Kodak EASYSHARE V1253 Digital Camera Logo
Posted on Oct 26, 2008
No pictures My camera stopped saving pictures onto the memory of the camera and the memory card. I tried buying a new memory card, but the camera won't save the picutures. It will show the picture right after it's taken but when I try to review the picture it's not found.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1069
Points
I also had the same problem - Finally solved it by reformatting the Memory Card on my Home Computer.
Note - It was not solved by using the delete pictures function on the V1253 Camera.
The problem only occured after I had used a friends Computer to delete pictures only from the Memory card.
Hope this helps!
How do i get pictures saved on the camera onto a memory card
Use the USB cable and the storage should become available when you plug the camera into a PC. You can buy the cable on ebay.
2answers
Card 'full' but no files found...olympus 1040
hi, there's a problem in your memory card and you need to do first is format the memory card into camera (if its ok to you to delete all the picture save in memory card). If the problem still occur you need to buy new memory card.
thank you and good luck my friend
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 2helpful
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    2helpful
    2answers
    I have a new memory card. I cant get pictures
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    I can't get to my pictures!
    did you buy a memory card along with your camera? I got the camera and they threw in a memory card with it for free. I now know why. My pictures will not always save onto this memory card. i took the memory card out of my old camera and put it in this one, and, the pictures saved. strangely, when i put my new card back in my new camera and took a picture; it saved to it again!
    so i believe this could work for you. it sucks. you lose the pictures. but atleast the camera does not have to just be thrown away.
    How do I transfer pictures onto the memory card?
    You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
    Kodak memory card error
    Hey hardygurl198,
    What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
    http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
    Sincerely,
    Allan
    Go Ahead. Use Us.
    Transfering problem
    Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
