Samsung L100 Digital Camera Logo
Posted on Oct 27, 2008
Samsung L100 Digital Camera Problem
I have a Samsung L100. I've only had it for 3 months and just yesteray, when I was trying to turn it on. It'd turn on, then the screen would go blank and it'd beep three times and shut off.
Can anyone help me out?
  • 8 more comments
  • Anonymous Dec 28, 2008
    i turn my camera on and the screen turns blank. Battery and memory chip was removed and then placed back in. Still does not work .
  • marieCCC Jan 01, 2009
    I have had the L1oo for 2 weeks. When I try to switch it on it switches itself off after bleeping 3 times.
  • hockeygirl56 Jan 21, 2009
    that did not work. the lens is stuck
  • ladyali Jan 26, 2009
    I have the samsung l100 and I haven't had it long at all, but long enough to not be able to return it. (go figure) It doesn't turn on all the time and when it does I'll try to take a picture and it'll turn off. Battery is fully charged. Also when I try to put it on the charger when I need to charge it the lite turns yellow and shuts off. Why????
  • Anonymous Feb 19, 2009
    Green light comes on, 3 beeps, light stays on screen not on nothing works. Tried removing battery, card etc. Ready to throw it out the window
  • Bella147 Feb 20, 2009
    Omg ive had my camera 4 months.
    I was at a party last night and when i took a picutre, i reviewed it and then it froze on the picture, wouldnt move or anything so i turned it off but the lens was stuck out and now when i turn it on, the screen is completely black anfd nothing happens. Ive charged it but still nothing. The lens is still stuck out and the only way to get the power off is to take the battery out.
    PLEASE SOMEONE HELP!
  • beatlesmania Feb 23, 2009
    I've had my camera about 8 months or so. Every once in a while, it'll get jammed *the lens will* & it wont work for days. Today, I was using it. Turned it off for a whle, went to ues it again & it wouldnt turn on, the power light was on & three beeps came out of my camera! It wont turn off until I take the battery out. Nothing on it will work & it wasnt dropped or anything. My camera lens wont even pop out!
  • Anonymous Feb 28, 2009
    This is the 3rd one that was replaced by the store and still doesn't work. When I hit the power the blue light comes on and then it beeps three times. But the camera still doesn't come on. It also seems as though its charged but then when u plug it in the color changes.
  • janechick66 Mar 01, 2009
    Have had camera since Boxing Day and it was working fine. Yesterday when trying to use it, it beeps three times then powers off. Really annoying as batteries etc were charged.
  • thacandymane May 11, 2010
    I did the same then beat it on the computer desk a couple of times and it works like a charm.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
993
Points
Right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Anonymous
Level 1:
  • Posted on Dec 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
993
Points
Turn the camera on then off. Turn the camera on, and while the camera is still on take out the battery and memory card. Put both back in and change the settings turn the wheel all the way around back to auto. try to take a picture. turn the camera off then on again. worked for me.
I want my lab top to see the cemera samsung l100 8.2
Having gone over a month without a response, I assume the suggested use of a card reader solved the problem.
13helpful
Dont know how to turn flash off on a samsung l100 camera.
Press the button with the lightning bolt icon and watch the screen. When you see a lightning bolt with a line through it, the flash is off.
2helpful
2answers
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
2helpful
Card error on L100 samsung camera, help please.
copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
2answers
Unable to download pics on my Samsung L100
have you check if you are using the usb cable or the av cable. the camera will not show anything on the screen if you are using the av cable and connect the camera to your computer.
I have a samsung L100 digital camera. the battery had to be recharged but the lens cover only partially closed at the time that it shut down. I tried to recharge the battery, when I turn on the power...
The battery was tested and showed to be fine. The camera just malfunctioned during the shutdown. The used battery was put into a new camera and it's been fine.
It was the L100 and I'm sending it out for repair. Warranty is still valid. Thank you.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
