Maytag MSD2756G Side by Side Refrigerator Logo
James Shreffler Posted on Feb 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag model MSD2651HEW replaced two refer side lights. New ones will not light
Side by side refergerator, lights bulbs were burned out so they were replaced. They now will not light. Wiring around bulbs and sockets appear in good condition. ???
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Feb 22, 2012
Anonymous
Expert
Level 2:
Answers
61
Questions
0
Helped
21146
Points
184
Some of the bulbs you buy at the stor the sucket pease is not long onoft try to scruit more or by them from a applice parts stor they little longet and make good contact
1 Related Answer
Anonymous
  • 999 Answers
  • Posted on Oct 12, 2009
SOURCE: Maytag Model MSD2651HEW - Changed Filter and
Was the pressure ok before you changed the filter? The water valve itself could be partially plugged or the supply line may be filling with minerals. Usually happens in the piercing tap used to attacc to the house line. Difficult to say for sure without seeing the way it is installed. If it was just the drinking water I would suggest the reservoir being froze up but since it affects both look at my initial comments...
Eric
MAYTAG Refrigerator MSD2351HES upper light burned very bright for few days, then broke
The light bulb just went bad.. replace it with a new one...
heatman101
1helpful
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
1helpful
Freezer buzzes then clicks off maytag model #msd2651hew
Replace the overload/relay . Part number 67005560 . You will need to pull the refrig out and remove the bottom panel . This piece , plugs onto the compressor , with 2 or 3 wires attached to it . You can easily replace . While back there , you may want to clean the "square" coils , of dust , lint , etc .
1helpful
3answers
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
3answers
MAYTAG fRG tm-1 Both of the
i think your defroster is gone..
you should think of replacing it with a new one
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
1helpful
2answers
Garage door opener light bulbs burning out
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
