Trying to run wires thru handle bar of my 1994 Honda Shadow vt1100c, I have both manuals for the bike but both books have black and white diagram and not too user-friendly.
SOURCE: how do I bleed the clutch on a 93 honda shadow VT1100C
Hydrolic failure is caused by mixing hydroscopic (DOT3) with petrolium based (DOT5) ater and oils don't mix. Blockage at return port won't allow fluid to return to master cylinder. Clutch will not engage if this were the case. The leak would be your best tell. Not knowing exact leak location it would be hard to say. inspection of master cylinder plunger seals couldn't hurt. If dissimular fluids have been mixed all rubber components have been contaminated and must be replaced
SOURCE: How do you get the battery out of a 1989 honda shadow 1100
Remove the Left side cover (as you are sitting on the bike).
Disconnect the negative cable first (left), then the positive. Remove the battery holder bolt (above battery). Lift up on the front of the battery and remove the vent tube. The battery will then come right out.
When installing new battery, make sure the vent tube is attached, and connect the positive cable before the negative. Sparks and batteries don't get along...
Please let me know if this helped.
SOURCE: i need wiring schematic
I bought a cbr 600 , but bike came with the wirers not connected. Rectafire, was also not connected? need diagram or help really badly!!!!
SOURCE: How to remove back tire on 1994 Honda Shadow
Heres a link to down load the manuel.
You may need to type in Verification code to get it.
http://www.carlsalter.com/verified.asp
