Sony TV channel stuck on 56 I need it on channel 3
I have a 1986 Sony TV model number KV-2775R. We don't have the remote control for it. We have been using the Cable remote and when we first got cable on it, it took the TW Tech about 20 min. and he finally got the TV on channel 3, but he didn't know how he got there. This time when I started messing with it the channels jumped from 2 to 4 and on up about 10 to 15 channels ending on 64. I gave the remote to my husband an somehow he got it stuck on channel 56 ( and he doesn't know how?). The nobs and buttons on the TV itself are from left to right... nob: video or ext-audio / nob: Auto Stereo; on or off (mono) / button: MTS / nob: sharpness / nob: brightness / nob: color / nob: hue / button: picture - / button: picture + / button: erase / button: add / nob: Cable; on or off / button: Timer/block / button: TV or Video / button: volume - / button: volume + / button: channel - / button:channel + / button: power
I can't use the channel up / down buttons because the TV is locked on channel 56. I also tried to put in channel 3 using the Time Warner cable remote control. I also tried using the channel up / down buttons on the cable remote control. nothing is working. Somehow we have gotten the TV locked on 56?
Thank you, for your help. I was hopping that the problem could be solved without getting the remote but that was your suggestion that we already thought we would have to do. Thanks though cause the price would have been much steeper if we had taken it anywhere.Thank you, for your help. I was hopping that the problem could be solved without getting the remote but that was your suggestion that we already thought we would have to do. Thanks though cause the price would have been much steeper if we had taken it anywhere.
You can't post conmments that contain an email address.
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Go to menu and select add/delete channels. Then select 02, or 03. Some channels that are selected the numbers will show green, channels not locked in will be red.
you have remote code together you bought a remote control,scan the page of the remote guide book, select TV look the number according to your TV Model there are one or three group of number .
press power,press tv enter code # press enter ,aim to the TV front .If the channel appear means the program activate the TV set.
sorry, I don't have an auto tuning / auto search button. All I have are the buttons and nobs that I listed in my original question?
