Question about Kenmore Elite 45986 Front Load Washer
Smell in washer
My washer smells like mildew in the inside of the washer now all my clothes smell like that also. I have changed detergent a couple of times and that did not help..
any ideas?
YOU SHOULD DIS CONNECT THE HOSES COMING FROM THE BACK OF WASHER AND SOAK IN BLEACH WATER ALSO CHECK THE DRAIN HOSE TO MAKE SURE WATER NOT LAING IN DRAIN HOSE CAUSING THE SMELL
Posted on Oct 27, 2008
  • 3 Answers
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
6ya staff
SOURCE:
My frigidaire front load washer smells like mildewed clothes; I have wiped down the inside and rubber seals...any ideas???
Here is a tip that I wrote about front load washers and the smells that seem to go along with them....
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
Aug 13, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer has a sour smell how do i get rid of smell
It sounds like you've got mildew somewhere in the washer. I'd recommend running a cycle, just like you would with a large load of clothes but WITHOUT the clothes, and use a full cup of bleach instead of detergent. You could let the basin fill and then turn the washer off to let the solution soak for an hour or so, and then complete the cycle. Bleach kills mildew...an and bunch of other stinky stuff too. Repeat if necessary.
Jul 01, 2010 | LG WM-2277HW Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mildew smell
Are you useing HE detergent? If not this is your problem! The reason why you need to use HE detergent is because it is made specifically for front load washers. The regular soap is made to be deluted in 20 gallons of water your washer only fills up with about 7. so what it does is it leaves a layor of residue SINKY SINKY. Especially when you leave the door shut all the time. It's like a Bathroom if you do not ventilate it properly it will Sink eventualy. So also please leave the door cracked open.
So to getr ride of the smell Sears sells a product called Afresh or Washer Magic I prefer the Afresh you get 3 tablets and it works great atr removing odors out of your washer. Also if you are on a Well wateer it is safe to use. Or you could use good old bleach with no clothes till the smell goes away
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Super Capacity Washer - Mildew smell
run the washer, with no clothes,
and 2 cups of bleach instead of detergent.
kills any mould in the washer
at least until you find the original cause, it wont stink
Oct 13, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
196 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
